easy 3s UPS relay short circuit problem
  • easy 3s UPS relay short circuit problem
Saad_Mahmoud
Saad_Mahmoud
Cadet
Posted: ‎2025-06-03 11:53 PM
725
the UPS easy 3s 3:1 15KVA unit began exhibiting intermittent and repeated faults while operating under normal conditions. The fault behavior is inconsistent and presents in two distinct patterns:
Fault Pattern 1:
  • All front panel LEDs turn off.
  • Only the Alarm and Output LEDs remain illuminated in green
  • The unit does not switch to bypass mode.
  • Occasionally, the Inverter LED lights up in red, and at the same time, the Alarm LED also illuminates in red, indicating a possible inverter-related fault
Fault Pattern 2:
  • The following LEDs illuminate in green:
    • Bypass
    • Output
    • Alarm
  • In this case, the unit transitions into bypass mode, supplying power to the load via the bypass line
In both scenarios, the system continues to cycle between normal operation and fault mode.
 Alarms and Error Messages
During these fault events, the following alarms are observed:
  1. Rectifier Inoperable
  2. DC Bus Overvoltage
  3. Relay Short-Circuit
KarimEissa
Commander KarimEissa Commander
Commander
Posted: ‎2025-06-04 03:07 AM
Regarding the raised faults ,probably  these PCBAs: output power board, input power board, rectifier power board and DC fuse detection board encountered a hardware malfunction and it needs to be  visually checked onsite after logs examining by our SRs or authorized service partners  ,so please contact your local CCC team and they will assist you for onsite visit to diagnose and replace the faulty boards accordingly
Karim
KarimEissa
Commander
Karim
MARIANOSB1
MARIANOSB1
Cadet
Posted: ‎2025-06-13 07:51 AM
HELLO KARIMM, COULD YOU HELP ME WITH THIS PLEASE, WHAT COULD IT BE? “PFC inactive”, “E:05 Rectifier not working” and “E:10 Incorrect DC voltage” on a 3M 160kVA Easy UPS
