Where can I download older versions of Powerchute?
  • Where can I download older versions of Powerchute?
5060
139
Erasmus_apc
Sisko Erasmus_apc
112
Posted: ‎2021-07-01 01:34 AM . Last Modified: ‎2024-03-06 01:33 AM
8223
Good afternoon.
I am trying to install Powerchute onto a Windows Server 2000 machine but can only find the version 9 download link on the APC site, which I believe isn't supported (and won't successfully install).
Does anyone know where I can source the slightly older (Server 2000 compatible) versions of Powerchute to work with my Smart UPS 1500I?
Thanks in advance.
Posted: ‎2021-07-01 01:35 AM . Last Modified: ‎2024-03-06 01:33 AM
Season's Greetings all!
Alas, one of my older servers is still running Win2K and I am in need of a copy of powerchute business edition v8.0.1.
Can anyone provide me with a valid link?
Thank you very much in advance.
Alex Craig
Would you be able to send me the latest version of Powerchute Business that will run on Windows Server 2000 please?
Thank you!
Replies 13
Alex Craig
8222
i did some research and the last version that appears to have windows 2000 listed as compatible was v8.0.1. I will private message you with a link to download 8.0.1
for reference, i checked http://www.apcmedia.com/salestools/ASTE-6Z5QEV_R19_EN.pdf
Edit for some reason it keeps telling me my private message is being rejected for an unknown reason. i'll email a link to you using your profile email.
Thank you!
Chris,
The last version of PCBE we officially support with Win 2000 is PCBE 8.0.1 and that version is only compatible with Smart-UPS SU, SUA and Matrix UPS. What model UPS will you be connecting the Win 2000 system to?
Hi Bill,
It's a Back-UPS Pro BX1000. Any hope?
Chris,
Back-UPS BX models are not compatible with PowerChute Business Edition. I suggest trying APCUPSD for monitoring software. I have never tested on Windows 2000 but suspect it would work. They offer a bin file so it is fairly straight forward to install.
If the newer release will not work they do also offer older version on their site.
I need version 8.0.1 for an older server. It's an APC SMART-UPS 1500
You can download the files from this link https://schneider-electric.box.com/s/wfm0pnj810t7ayulm7i8du5tjlryz3ko
NOTE: PCBE 8.0.1 is out of warranty and support has ended.
I would need to install latest available versions of PCNS for Windows Server 2003 64, Windows Server 2008 R2 64-bit bit and Windows Server 2008 64-bit
Could you please provide links to download?
BR, Wojtek
PowerChute Network Shutdown 3.1 is compatible with Server 2003 64bit https://schneider-electric.box.com/s/cnxgdtgb0irhjqop0nuimpf9qcssk06g
PowerChute Network Shutdown 4.2 is compatible with Server 2008, 2008 R2 64bit
https://schneider-electric.box.com/s/k68q5w4i0hfhyobhikziep6hdgiws31a
These versions have been discontinued, and support has ended. They have not been updated to meet the latest cybersecurity policies and should be used at your discretion.
KD_L
KD_L
Cadet
Posted: ‎2023-04-25 03:52 PM . Last Modified: ‎2023-04-25 03:53 PM
In response to BillP
Hi Bill
Is it worthwhile to buy APC Back-UPS Pro 1500VA for a Windows 2000 server? I would like to use the Powerchute software to trigger shutdown on the Windows 2000 Server. Do you know where to download Powerchute (APC Back-UPS 1500VA) for Win2K Server?
Regards
KD_L
  • older versions of Powerchute
  • Sever 2000
balthazar_blue
balthazar_blue
Cadet
Posted: ‎2024-08-07 11:46 AM
This is a really old thread, but I'm hoping it's my best chance at help.
I recently got a UPS for home use, and want to install PowerChute Personal Edition, but the available versions aren't compatible with my Windows Home Server.  PowerChute Personal Edition 3.1.0 won't install and shows an error it's not compatible.  PowerChute Serial Shutdown won't install either, giving an error that it's a 64-bit application and the operating system on my home server is 32-bit.
I'm hoping there's an older version that will work.
