Posted: 2021-06-29 06:04 AM . Last Modified: 2024-03-13 12:05 AM
I just received two Proliant DL380's each with two 750W PS's. I am trying to, A. Figure out what their actual power consumption will be (not much more than idling I would say) and B. What the best UPS would be.
My company has proposed either the smart ups 1500 or 3000, thought there are multiple options for either. I like the idea of purchasing the 3000XL because we could potentially later on purchase an additional battery back up.
Any input on this topic would be appreciated. I did find a document from HP stating that a standard DL380 will run at around 245W per PS. This still seems a bit excessive as the backup estimate from this site states that the 3000 powering just these two servers would last maybe a minute.
Posted: 2021-06-29 06:04 AM . Last Modified: 2024-03-13 12:04 AM
Yes I agree. And Battman has a great suggestion. That tool is probably your best bet to measure the consumption at the heaviest use time of the servers.
It might not be a bad idea to see what our UPS selector says as well: UPS Selector Sizing Applications
I use one of those "green products" they sell for measuring power consumption around the house for this purpose. Its a handheld device made by P3 International and is called a KILL A WATT...and only cost about $40.
Most server power supplies are autoranging and will run on 120 volt in addition to 208 volt so you can plug a pair of standard PC power cords into the server, have them go to a power bar and then plug the power bar into the KILL A WATT.
Here's a Youtube video: How to measure power consumption (wattage/amperage) of any item or device - personal power meter $20...
Good luck!
I used the UPS selector initially using total wattage as my criteria. I think this could be more accurate if I knew what my actual consumption rate will be. I then just selected my devices and had the calculator advise me of the best solution. I will be purchasing the UPS based off of this calculation. Though in truth I still feel as if I am making a bling purchase as I am not sure what my servers will actually draw. I guess the lucky aspect of this is that my company is paying for this item and I am not.
@Anonymous user, that sounds like a helpful device. Thanks!
