Posted: 2021-06-30 06:56 AM . Last Modified: 2024-03-07 11:44 PM
Hi All,
We have a Smart-UPS 3000XL with the NMC AP9719 successfully installed and working with the latest 3.5.5 firmware. We've successfully configured one Macintosh (OS X 10.3.9) as test Server "A", which does connect and shutdown per the selected Shutdown Events. Now we want to silent install this onto a test Server "B" (OS X 10.4.10). We've followed APC's directions but can't complete the installation.
While logged in as root, after typing this command (step 6, Page 6 of 10, see attached):
chris-powerbook:/usr/local root# sudo java -cp .:pcns200.jar:swingall.jar:util.jar load -q /pcns200_PPCdPrinter/silentInstall.ini
We get the following error:
Exception in thread "main" java.lang.NoClassDefFoundError: load
Can anyone shed some light on how to solve this? We have 10 servers to install this, and were hoping to streamline this initial setup, as well as re-configurations as needed.
Thanks in advance for any help.
Posted: 2021-06-30 06:57 AM . Last Modified: 2024-03-07 11:44 PM
Hi All,
Well, I've decided to skip this silent install and try installing one by one, but copy the "m11.cfg" file from the pre-configured server to the newly installed server(s). It seems to work (so far) as long as I shutdown the PCNS services first, then overwrite the original m11.cfg file. The settings do transfer to the other server(s).
If anyone reads this and knows that this is NOT a good idea - please let me know! Otherwise, I hope this helps others looking for a workaround to the silent install.
Cheers.
Thanks for the reply - we're using:
java version "1.5.0_07"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_07-164)
Java HotSpot(TM) Client VM (build 1.5.0_07-87, mixed mode, sharing)
We gave up on the silent install, and we decided to just copy the m11.cfg file and it seems to be working.
Thanks for your help.
Hi All,
