Ask Me About Webinar: Data Center Assets - Modeling, Cooling, and CFD Simulation Join our 30-minute expert session on July 10, 2025 (9:00 AM & 5:00 PM CET), to explore Digital Twins, cooling simulations, and IT infrastructure modeling. Learn how to boost resiliency and plan power capacity effectively.Register now to secure your spot!
Unable to import certificate using APC Security Wizard
Send InviteCancel
I've generated the private key and CSR, and used the CSR to generate a new cert. I've then downloaded the resulting cert in both DER and Base64 format (the guide doesn't specify which it needs).
However, no matter which cert I use, when I use the wizard to Import the certificate with the private key file, I get: Error importing cert, code: -32.
I can't seem to find any information about what the error code means. Can someone help?
