NMC: What Authentication Phrase?
Send InviteCancel
Posted: 2021-07-0104:35 AM. Last Modified: 2024-03-0502:06 AM
I'm setting up NMC but it doesn't work. I can't get it pass this error message:
"Those changes have been applied, but the NMC connection was NOT successful. Your computer may not be protected. It is recommended that you fix these issues immediately.
ERROR: NMC http://xx.xx.xx.xx:80 found, but security information is incorrect. Check the Authentication Phrase and User Name."
There was already a passphrase in the field (which I can't see of course) and I don't remember setting one.
I also tried what I found was the default passphrase "admin user phrase".
