USB does not work when the UPS is turned on after discharge
Send InviteCancel
Posted: 2021-06-2807:14 AM. Last Modified: 2024-03-1812:44 AM
Hello, I have purchased the BX700UI UPS, when running on the battery after the UPS has been discharged and shut down, the UPS will re-connect to the network but after the server has started, the server (the Linux operating system) can not see the USB communication. USB communication is renewed until the battery is removed and reinserted (battery connector). Do not you know if this UPS error is? Or what could cause the USB to go out after a full battery discharge? Thank you Best regards, Michal Cepelak
