Posted: 2021-06-29 08:18 AM . Last Modified: 2024-03-12 03:08 AM
Why two "not installed" "already installed" alarms occur frequently. The UPS is Smart-UPS 3000 RM with AP9630 card. It sounds the battery is new and from APC. The product detail as below:
apc>about
E000: Success
Hardware Factory
Model Number: AP9630
Serial Number: ZA1241005544
Hardware Revision: 05
Manufacture Date: 10/04/2012
MAC Address: 00 C0 B7 98 A4 46
Management Uptime: 78 Days 17 Hours 59 Minutes
Application Module
Version: v5.1.7
Date: Dec 1 2011
Time: 13:01:45
APC OS(AOS)
Version: v5.1.7
Date: Nov 22 2011
Time: 09:53:57
APC Boot Monitor
Version: v1.0.2
Date: Jan 21 2010
Time: 13:35:57
E000: Success
Status of UPS: On Line, Bad Battery, No Other Alarms Present
Last Transfer: Due to software command or UPS's test control
Runtime Remaining: 8 hr 30 min
Battery State Of Charge: 100.0 %
Output Voltage: 117.3 VAC
Output Frequency: 60.0 Hz
Output Watts Percent: 11.7 %
Output VA Percent: 11.7 %
Output Current: 3.00 A
Input Voltage: 117.3 VAC --->I did check few times within 1 hour , sounds the input voltage is stable
Battery Voltage: 54.5 VDC
Internal Temperature: 36.9 C, 98.4 F
Self-Test Result: Not Available
Self-Test Date: 05/23/2014
Calibration Result: Not Available
Calibration Date: Unknown
Posted: 2021-06-29 08:19 AM . Last Modified: 2024-03-12 03:08 AM
When you see this type of thing, it is likely the battery, or very rarely, the UPS and it's ability to detect that the battery is present. If a self test is not completing, it sounds like there is a problem with this battery and it's capability to support the load properly. I see a couple of instances in data.txt, where the battery voltage has dropped way down.
Anyway, if this is a genuine APC replacement battery, you'll need the serial number on that replacement battery and depending on what that is, a proof of purchase possibly, and then you'll want to pursue a replacement with tech support in my opinion. Something isn't right with it. If a new battery does not solve the issue (which I think is unlikely), then it may be a problem with the UPS. I doubt this because of the voltage drops in data.txt - they seemed to indicate an issue with the battery to me.
If it turns out it is not a genuine APC replacement battery, then you'd want to pursue a replacement with wherever it was purchased.
I tried to do self-test , it sounds all attached devices are rebooted , but the UPS doesn't reboot.
apc>ups -st
E000: Success
State: On Line, Bad Battery, No Other Alarms Present
apc>about
E000: Success
Hardware Factory
Management Uptime: 78 Days 18 Hours 26 Minute
apc>detstatus -all
E000: Success
Status of UPS: On Line, Bad Battery, No batteries installed, No Other Alarms Present
Output Voltage: 118.0 VAC
Input Voltage: 118.0 VAC
Self-Test Result: Invalid
