Share Your Feedback โ Help Us Improve Search on Community! Please take a few minutes to participate in our Search Feedback Survey. Your insights will help us deliver the results you need faster and more accurately. Click here to take the survey
Posted: โ2021-06-30 01:11 AM . Last Modified: โ2024-03-11 03:10 AM
Is there a way to fine-adjust the output voltage of a Symmetra LX 16kVA?
I would like to go from the standard 240V to 243V to compensate for the voltage drop in a 150ft feeder (UPS and load are in separate rooms). I checked the PowerView menus on the unit but didn't see anything there. Maybe through software?
Just in case you were wondering...
... the feeder wires are already oversized to minimize voltage drop (4/0 alum)
... the load includes a few CFL bulbs that buzz when the voltage is just a bit below 120V, should probably replace them with LED bulbs anyway
unfortunately, you can only set the output voltage to either 200v, 208v, or 240v. you cannot change it to a specific integer value or anything.
Oh well, I'll live ๐
Thanks for answering my question
no problem ๐
Youโve reached the end of your document
