Symmetra LX 16KVa - PM won't shut down
Showing results forΒ
Did you mean:Β
  • Symmetra LX 16KVa - PM won't shut down
5060
138
Erasmus_apc
Sisko Erasmus_apc
112
MarkGinger_apc
Lieutenant MarkGinger_apc
Lieutenant
Posted: β€Ž2021-06-26 05:42 AM . Last Modified: β€Ž2024-03-19 12:38 AM
998
We have a 16KVa Symmetra LX with a defective PM. We've replaced these before and it's pretty straight forward. At the moment for this dead PM when we unscrew the locking PIN, the PM doesn't power down, or get removed from the system. If we just pull it out, will there be any consequences? Is there a way to manually shut down the PM? What's the procedure for this?
Thanks for your help!
  • Data Center & Facility 3 Phase UPS
have you tried to gently tap the thumbscrew down? maybe the latch is still caught?
Replies 6
MarkGinger_apc
Lieutenant
Will try that and let you know
MarkGinger_apc
Lieutenant
Yes, no response from the system.
i would suggest that you go into maintenance bypass and then try to pull it out. if it still does not come out, it makes me think the latch still is caught possibly.
MarkGinger_apc
Lieutenant
The latch and screw come out. We put the system into by pass, however the fan on the PM is still spinning and it's still showing it as a bad PM. Can I just yank out the dead PM while the system is in by pass?
yes, bypass does not stop the fan from spinning. in bypass, just yank it out and then remember to take it out of bypass later πŸ™‚
Β
