SmartUPS SUA3000UXI battery charge cutoff voltage
  • SmartUPS SUA3000UXI battery charge cutoff voltage
145
Posted: ‎2021-06-29 06:30 AM . Last Modified: ‎2024-03-12 11:27 PM
3090
I'm using two SUA3000UXI systems with an external 48V battery bank, and wanted to know at what
voltage level the built-in charger is set to cut-off, and whether this voltage level can be tuned using
Powerchute or console access.
Sanjay
Posted: ‎2021-06-29 06:31 AM . Last Modified: ‎2024-03-12 11:27 PM
We don't have these units in NAM so I don't have much data on them unfortunately. For more specific data, your local customer care center might be able to research it further.
All I know at this point specifically with my resources here in NAM is that the system is designed for a 48V Lead Acid battery system.
Replies 7
These UPSs will become programmed with a float voltage setting (somewhere around 55.XX vDC to keep batteries at the proper float voltage for a 48V system) and it is not something the user could adjust or should ever need to adjust while using the UPS in a supported manner (so we don't need to give users the ability to change it).
Angela, thanks for the quick response.
>> (somewhere around 55.XX vDC..)
Is an even more precise float voltage indication available?
Sanjay
I don't honestly know the actual value unfortunately but either way, I don't think I'd be allowed to post it here.
What's the boost and absorption voltage on this model?
Not the auto voltage regulation on the (AC) input side, but the charging protocol for the battery.
i.e the boost, absorption and float voltage levels for the three-stage battery charging, that is
typical for lead acid batteries
Are you talking about Automatic Voltage Regulation or something else?
