Smart-UPS serial communication
  • Smart-UPS serial communication
Posted: ‎2021-07-01 04:21 AM . Last Modified: ‎2024-03-05 02:22 AM
2447
I have a Smart-UPS 3000LCDRM2U installed and try to setup the serial connection to an old Solaris 9 system.
Same machine worked with an old Smart-UPS 3000 (without LCD) and the old PowerChute Plus software without problems until the UPS died.
The new UPS will not communicate with PowerChute Plus or PowerChute Business Edition 8-9.0.1.
I already tried baud rates 2400, 9600, 19200, but no communication established.
Do I need to enable the serial port at the UPS first?
And if, how?
I dont have direct access to the UPS, only remote access to the server, and I am not familiar with the setup at the UPS front panel!
Thanks for help
Guenter
  • communication
  • serial
  • smart-ups
  • solaris
Thanks for sharing what did work for you. That is strange since that UPS communicates at 9600..
Replies 9
Can you confirm what serial cable part number you have in use? Can you also confirm the exact model of the UPS? I am thinking it starts with SMT or SMX which definitely requires PowerChute Business Edition v8.5.1 or higher to support communications with SMT or SMX model UPSs.
I am not sure about other specifics on Solaris. Bill P. - anything else you could add?
The UPS model is: SMT3000RMI2U
The serial cable part number is: 940-0625A
I have restartet the UPS and the server, the server serial device is ttyb which is configured in the software.
Also I tried several different settings on the serial interface on the server.
So far I know is the serial setting of the UPS 9600-8N1.
At the moment I am trying PCBE 9.0.1 (the last one for Solaris?), I can switch back to 8.5.1
The test with PCBE 8.5.1 has the same result: no communication.
I also tested the PCBE settings for SMT,SMX and also for Smart-UPS, which one is the correct one for this UPS?
The last version on PCBE to support Solaris 9 is version 8.0.1. Unfortunately your Smart-UPS is not compatible with version 8.0.1. Your option is to purchase our legacy communication card and then you can continue to run PowerChute Plus or install PCBE 8.0.1. I would recommend using PC+ since that is what you are familiar with. Here is a link to the cards web page Buy Legacy Communications SmartSlot Card - Technical Specifications and Information | APC
The readme.txt of the PCBE 8.5.1 stated this:
     The PowerChute Business Edition Agent is compatible with Solaris 9 and Solaris 10
Now you say the last version for Solaris 9 is PCBE 8.0.1.
What is correct now?
Another question:
the firmware level of the new UPS is 8.3.
Is this ok for the legacy communications card?
Or is a firmware upgrade needed? I could'nt find anything about this.
I ask, because the customer is able to install the card and the cables, but not the firmware.
For this I have to drive some hundred kilometers.
Edit: firmware version
Yes, the firmware will be fine. Here is the LCC compatibility chart -> AP9620 Legacy Communications Card (LCC) Compatibility | FAQs | Schneider Electric US
Now I got it up and running! laughing
It is still Solaris 9 and it is running with PCBE 9.0.1!!!
For any future records: What it needs for correct setup was:
1. Setup the eeprom for ttyb
# eeprom | grep ttyb
ttyb-rts-dtr-off=true
ttyb-ignore-cd=false
ttyb-mode=2400,8,n,1,-
!! reboot !!
2. Setup ttyb in SMC (Solaris Management Console)
Baud rate: 2400, software handshake, Initialize only
Thanks for your help and have a nice weekend!
