Posted: 2021-06-28 05:51 AM . Last Modified: 2024-03-18 03:05 AM
I am not able to see the internal temperature on my Smart UPS SU620 on PowerChute BE 9.1.1. I have to admit, I do not recall if it was present on the other versions of PCBE. It seems that this is a basic metric and should be visible.
I just replaced the battery and performed the calibration within PCBE 9.1.1.
Should it be viewable? If so, what should I look for to get it to sense the temperature.
Posted: 2021-06-28 05:51 AM . Last Modified: 2024-03-18 03:04 AM
If I had a schematic, I could figure it out myself.
I do not have a 620 available for testing but my recollection is that data point is not available. Maybe another forum member that has a 620 will help out. Some of the lower end Smart-UPS did not offer all of the same data points and the higher end ones do and that may be the case here.
Posted: 2025-06-12 06:45 PM
I guess there is no real solution. Why it is marked as solved is ludicrous!☹️
Posted: 2025-06-13 04:29 AM
You can open the unit up and confirm there is a NTC temperature sensor inside. If present it would be strapped to the inner housing with a zip tie and inserted into a formed cutout in the metal case which points toward the battery compartment.
If the sensor is not present you have your answer. If the sensor is present you may try the following software applications to see if it appears: APC PCSS, NUT, APCUPSD.
Report back your findings as I’m sure the information will help the next person asking the same.
Questions Ask . . . 👍
