Smart-UPS RT 5000 XL: A battery bus soft start fault no longer exists
  • Smart-UPS RT 5000 XL: A battery bus soft start fault no longer exists
Posted: ‎2021-06-29 05:52 AM . Last Modified: ‎2024-03-13 12:23 AM
2851
I am receiving below alert  Smart-UPS RT 5000 XL: A battery bus soft start fault no longer exists.?
Could any one let us know about it.
01/25/2015 10:40:20 System: NTP update successful.
 01/24/2015 10:40:15 System: NTP update successful.
 01/23/2015 19:57:33 UPS: In bypass in response to an internal hardware fault.
 01/23/2015 19:57:33 UPS: A battery bus soft start fault exists.
 01/23/2015 10:40:11 System: NTP update successful.
 01/22/2015 10:40:06 System: NTP update successful.
 01/21/2015 10:40:01 System: NTP update successful.
 01/20/2015 10:39:56 System: NTP update successful.
 01/19/2015 10:39:51 System: NTP update successful.
 01/18/2015 10:39:47 System: NTP update successful.
 01/17/2015 10:39:42 System: NTP update successful.
 01/16/2015 10:39:37 System: NTP update successful.
 01/15/2015 10:39:32 System: NTP update successful.
 01/14/2015 10:39:27 System: NTP update successful.
 01/13/2015 10:39:23 System: NTP update successful.
 01/12/2015 10:39:18 System: NTP update successful.
 01/11/2015 10:39:13 System: NTP update successful.
 01/10/2015 10:39:07 System: NTP update successful.
 01/09/2015 14:01:43 UPS: passed a self-test.
 01/09/2015 14:01:34 UPS: Started a self-test.
 01/09/2015 10:39:03 System: NTP update successful.
 01/08/2015 21:12:25 UPS: The power for switched outlet group 3, Outlet Group 3, is now turned on.
 01/08/2015 21:12:25 UPS: The power for switched outlet group 2, Outlet Group 2, is now turned on.
 01/08/2015 21:12:25 UPS: The power for switched outlet group 1, Outlet Group 1, is now turned on.
 01/08/2015 21:12:23 Environment: Restored the local network management interface-to-integrated Environmental Monitor (Universal I/O at Port 1) communication.
 01/08/2015 21:12:23 UPS: Restored the local network management interface-to-UPS communication.
 01/08/2015 21:12:01 System: Network service started. IPv6 address FE80::2C0:B7FF:FE5B:4AE3 assigned by link-local autoconfiguration.
 01/08/2015 21:11:57 System: Network service started. System IP is 156.127.161.248 from manually configured settings.
 01/08/2015 21:11:51 System: Warmstart.
Replies 4
can you post the entire data.txt and event.txt log so we can get a better understanding of what is happening with the UPS?
these logs can be downloaded via FTP from your network management card where the alerts are coming from. instructions are in our knowledge base (FAQ) in article ID FA156131.
Hi Angela,
I have a Smart-UPS X 3000 with the same error:
  Critical Alarm 1 Critical Alarm Present
◾Battery Bus Soft Start Fault
And the status look good:
Status Smart-UPS X 3000
Last Battery Transfer: None
Internal Temperature: 22.3°C
Runtime Remaining: 2hr 6min 20sec
UPS Input
Input Voltage: 240.0 VAC @ 50.1 Hz
UPS Output
Output Voltage: 240.0 VAC @ 50.1 Hz
Load Current: 0.8 Amps
Output VA: 6.9 %
Output Watts: 7.6 %
Output Efficiency: 87.6 %
Output Energy Usage: 1410.85 kWh
Battery Status
Battery Capacity: 100.0 %
Battery Voltage: 53.9 VDC
Num of External Batteries: 0
Can you help me to fix this issue? Thank you in advance.
Vuong
Your UPS and the original poster's UPS are different models. on SURT, sometimes this can be related to a bad battery but on SMX it is generally a hardware fault.
Could you provide the log files I requested from the original poster? I'll take a look and see if anything else jumps out at me.
