Smart UPS 1500VA with VmWare Server?
Showing results forΒ
Did you mean:Β
  • Smart UPS 1500VA with VmWare Server?
Posted: β€Ž2021-06-28 09:22 PM . Last Modified: β€Ž2024-03-15 12:34 AM
832
Hello!
First post here πŸ™‚
I have a HP Proliant ML370 running Windows 2003 Server Entperprise. Vmware Server 1.08 is installed at the host and on this machine i am running two virtual machines. 1 Windows 2003 SQL server and 1 Windows 2003 Webserver.
To the ML370 there is a Smart UPS 1500VA connected. I have now installed Powerchute Business Edition Agent at the host (not on the virtual machines). What do i need to install on my virtual machines to also make them aware of my UPS? IN case of a powerfailure i would like my Windows 2003 VmWare Server host to gracefully shutdown my 2 virtual machines and then shutdown itself. Is that possible with my current setup?
Thanks in advance.
/Rickard
Message was edited by: Rickard
Comment myself πŸ™‚
I created a batfile and placed it in C:\Program Files\APC\PowerChute Business Edition\agent\cmdfiles\apcvmshut.bat. It look like this:
@START "" "C:\Program Files\APC\PowerChute Business Edition\agent\cmdfiles\vmshutdownweb.bat"
@START "" "C:\Program Files\APC\PowerChute Business Edition\agent\cmdfiles\vmshutdownsql.bat"
apcvmshut.bat starts the two batfiles i refer to above (vmshutdownweb.bat and vmshutdownsql.bat) and these files look like this:
vmshutdownsql.bat
cd c:\program files\vmware\vmware server\
call vmware-cmd "D:\Virtual Machines\SQL\sqlserver.vmx" stop SQLSERVER
vmshutdownweb.bat
call vmware-cmd "D:\Virtual Machines\SQL\webserver.vmx" stop WEBSERVER
Then from the Powerchute webinterface (Business edition) i select Command File Name: apcvmshut.bat and set Command File Execution Duration to 30 seconds and OS Shutdown Delay to 90 seconds.
Havent tried this yet but hopefully it will work :). The BAT-files work because i have tried them manually. Anynone else have tried this something similar to this and have comments?
Thanks.
Comment myself πŸ™‚
vmshutdownsql.bat
vmshutdownweb.bat
Thanks.
Β
