Smart UPS 1500I -
  • Smart UPS 1500I -
Posted: ‎2021-06-30 07:19 AM . Last Modified: ‎2024-03-07 11:13 PM
1099
Smart UPS 1500I -
I had this unit for five years now. I always replaced batteries with genuine APC at least two times: not a single issue.
Recently, I have removed the UPS for scheduled maint, cleaned the ventilation holes and then put it back but without connecting any load. When I turned on the device, it performed a self-test which was not successful. The display showed a fault red light and the message: "fault state: output over volt". By attaching all the load back, and cycling the UPS power OFF-ON, the self-test was successfully passed. The load was 12% (120W).
If I attach something lower than 120W, the UPS won't pass the self-test neither is able to provide UPS protection to the outlets if the AC cable is removed (batteries fully charged).
Question #1:
Is there a Minimum load under which the UPS can't operate?
Question #2:
It is normal to get the "fault state: output over volt" without load?
I suspect a system malfunction because other UPS I have installed (different maker) are able to work and perform a self-test with no load attached. In this case, is there something I could do to verify the device?
Thank you very much,
Adam.
  • fault
  • output
  • over
  • state:
  • volt
After nearly two months, no answer!
Anyone?
Thank you,
AH
Anyone?
Thank you,
AH
