Smart-UPS 1500 own event script
Send InviteCancel
Posted: 2021-06-2806:35 AM. Last Modified: 2024-03-1801:19 AM
Hi everybody,
I'm trying to write me own script to turn off my power amplifier after 60 second power loss. I decided to use timeout event. I wrote own script as below:
echo "TAV250 -> OFF AIR (in progress) ---" | ${WALL} /home/ldadmin/dev/tav250/tav250_offAir.py echo "TAV250 -> OFF AIR (done) !!!" | ${WALL}
exit 99
The problem is that even UPS is 100% charged, when I unplug power cord after 60s the apccontrol first shutting down my system and after this is trying to execute my script (I'm able to see first echo from my script). Maybe im wrong, but according to documentation my script should be executed first not the second. And second thing, if I exit 99 after executing my script apccontrol should do nothing? So why is shutting down my system?
Thank for any help to solve my problem,
Best regards Michal
/var/log/apcupsd.event
2017-09-14 14:05:14 +0200 apcupsd 3.14.12 (29 March 2014) debian startup succeeded 2017-09-14 14:05:15 +0200 Power failure. 2017-09-14 14:05:21 +0200 Running on UPS batteries. 2017-09-14 14:06:22 +0200 Reached run time limit on batteries. 2017-09-14 14:06:22 +0200 Initiating system shutdown! 2017-09-14 14:06:22 +0200 User logins prohibited 2017-09-14 14:06:22 +0200 apcupsd exiting, signal 15 2017-09-14 14:06:22 +0200 apcupsd shutdown succeeded
