Smart-UPS 1500 behind Photvoltaik UPS
  • Smart-UPS 1500 behind Photvoltaik UPS
5060
139
Erasmus_apc
Sisko Erasmus_apc
112
quaker
Crewman quaker
Crewman
Posted: ‎2025-01-07 06:00 AM
2087
Hi all,
I have a Smart-UPS 1500 that has generally worked flawlessly until we installed a photovoltaic system with a battery storage unit. The PV storage switches seamlessly in the event of a power outage, and everything runs as it should. However, ever since the power comes back on, the Smart-UPS 1500 briefly switches off and then back on. As a result, my server shuts down. What could be causing this behavior, and is there a way to fix it?
Replies 7
Kirk
Posted: ‎2025-01-08 08:44 AM
2059
You’ll need to provide the following information such as the event, data, ups logs.
Provide the exact model UPS, serial number, UPS ID & Firmware installed.
Show me a clear photo of the back output (outlets) of the rear of the system. Provide an image capture of all the settings relating to power quality for the UPS.
Lastly, show me the battery installation date and the production sticker on the cartridge. If the UPS system is connected to a server and has APC Power Chute software disconnect the USB cable.
If there is another power blip report back how the system behaves without the USB cable connected to the server. ☝️
Questions Ask . . . 👍
quaker
Crewman quaker
Crewman
Posted: ‎2025-01-15 03:59 AM
In response to Teken
1997
sorry for delay. Here are the requested information.
Kirk
Posted: ‎2025-01-15 07:48 AM
In response to quaker
Please indicate the model, serial number, UPS ID (Firmware). Battery installation date, battery production sticker.
Has the USB cable been disconnected from the computer running PCSS?!? If so has there been any problems where the power blipped and the UPS behaved improperly?
quaker
Crewman quaker
Crewman
Posted: ‎2025-01-16 01:48 AM
1959
USV-Modell: Smart-UPS 1500
Seriennummer: AS1712151498
Firmwareversion: UPS 09.3 / MCU 19.0 (18 - 19)
Battery installation date 03/2019
battery production sticker. -> where to find?
No, not yet. But at the meoment no power cut off happend.
Kirk
Posted: ‎2025-01-16 04:21 AM
Assuming you have never changed out the battery cartridge. Based on the information you have provided the battery cartridge is six years old.
The average service life of the battery cartridge is 2-5 years based on usage, temperature, and environmental conditions.
You’ll need to perform a static & dynamic load test of the system to gauge how the system performs.
Static: Remove all connected loads from the outputs. Disconnect AC Mains from the wall and time how long the unit runs.
Dynamic: Ideally you would have the same connected loads such as your servers connected. But you may replace them with anything such as a fan, heater, etc.
Remove AC Mains from the unit and time how long the system operates for and compare it to the APC Runtime Calculator.
There will be three possible outcomes for the two tests. Immediate shutdown, very short runtime, to average runtime when compared to a new battery cartridge.
Report back what you see and observe upon completing both static & dynamic load tests.
NOTE: The battery production date is either stamped (silkscreened) or identified by a alphanumeric sticker that is white / white-yellow.
quaker
Crewman quaker
Crewman
Posted: ‎2025-01-23 01:22 AM
1890
Hi, test done, removed Main power and testet runtime with complete load.
runtime with load ~20mins
Kirk
Posted: ‎2025-01-23 03:20 AM
Leave the USB cable disconnected from the two systems. Report back once there is a power outage and what you see and observe.
