Smart UPS 1500 - battery disconnected message; replace UPS or battery?
Showing results forΒ
Did you mean:Β
  • Smart UPS 1500 - battery disconnected message; replace UPS or battery?
Posted: β€Ž2021-06-29 12:02 AM . Last Modified: β€Ž2024-03-14 01:05 AM
11184
Agent version: 7.0.4.114
OS: Windows 2000 5.0
Model: Smart-UPS 1500
Serial: AS0618111860(
Manufacture: 4/28/2006
Firmware: 601.3.D
Battery Replaced: 4/28/2006
Status: No Batteries Attached
Output voltage: 123.1 VAC
Input voltage: 123.1 VAC
Self-test result: Failed
We have been using our SmartUPS 1500 for over three years at very low load and have had no problems until this:
Monday morning, the server had suffered a reset and the UPS was beeping every few seconds. I assumed that perhaps the battery was in need of replacement, but further investigation shows that the unit thinks the battery is unplugged. I find this notion physically improbable(ninjas? earthquake?).
I unplugged everything from the UPS and left it off and plugged in for 48 hours to try to recharge the battery.
Now when I turn it on, everything is green for a few seconds then it goes back to the battery disconnected mode (red light blinking and beeping every few seconds).
Event Log:
12:10:34 Battery Reconnected
12:10:40 Battery Disconnected
I want to know if I should buy a replacement battery or a replacement unit. I would hate to buy a battery only to find out that the unit's circuitry is the problem and have to spend even more money.
Great! Glad order is restored. πŸ™‚
Replies 4
You probably either have bad batteries (the voltage could be so low it isn't detecting them) or the sensor in the UPS isn't working. If you can, you could try a pull-plug test to see which it is - if the UPS stays on with the power cord unplugged, it's just a bad sensor. If it turns off, you need new batteries. Since the batteries are over 3yrs old (almost 4 actually, based on the manufacture date), that's entirely possible.
Then again, ninjas are sneaky...
Thank you for the quick response.
I pulled the cord and the unit immediately shut off.
We will be ordering a replacement battery pack post-haste.
I shall post the results when I have some.
Replaced the battery. All is well.
Β
