Setting default state per outlet on AP8930
  • Setting default state per outlet on AP8930
5060
142
Posted: ‎2021-06-28 12:05 AM . Last Modified: ‎2024-03-18 11:41 PM
1911
I would like to set the default state of each outlet on an AP8930 so that when I power on a PDU certain outlets always are on and others are off.
How can I do this in the administration console?
  • AP8930
Hi Robert,
With this PDU, you can configure certain outlets to always be off, unless you turn them back on manually. This is done by going to Configuration -> RPDU -> Switched Outlet -> Configuration. See below:
Then you click on which outlet you would like to configure, and under Switched Outlet Functionality, the default state is Immediate Power On, but you can also choose Never Power On or set a power on delay. See below:
Let me know if that setup will work for you.
Nicole
Posted: ‎2021-06-28 12:05 AM . Last Modified: ‎2024-03-18 11:40 PM
Thank you!
Hi Robert,
Nicole
Thank you!
