Posted: 2021-06-28 10:54 PM . Last Modified: 2024-03-14 03:55 AM
Dear Team,
we are facing problem SURT 10KVA UPS when we cold start the UPS it is working fine we connect input power UPS is online and working normally and then when we turn off the UPS and again connect input power without cold start now UPS is showing fault internal fault LED and battery LED top to 01001 we off the UPS on front penal UPS showing again different fault battery LED 00101 please see below attachment please provide us of this problem remedy your response will be highly appreciated
Zakir
Message was edited by: zakir
Posted: 2021-06-28 10:54 PM . Last Modified: 2024-03-14 03:54 AM
Hi Zakir,
I would suggest that you contact the APC Customer Care Center for your region. You can contact them using the following numbers.
- 971 4 7099 691 (English)
- 971 4 7099 690 (Arabic)
Dear Team,
Zakir
That's a bypass relay fault. Is the load still running off the UPS? When did this fault come up? How often has the UPS been going to bypass (if at all) and what is the input/output voltage (both measured and the setting on the unit)?
This fault usually will not clear but if you can try toggling bypass on the unit when there is no load, and also "braindeading" the UPS, this could help fix the issue. To braindead the unit, cut the input power to the unit, make sure the unit is off, and hold the "OFF" (circle) button until you hear a faint click.
thanks for supports we are try to rapier it we change relays RY1401and RY1402 and relay drive but UPS still showing Fault we are replace controller card with new one now UPS is showing still error please let me know how to remove this fault or which component need to be replacement as well all the circuit track are looking OK
Input voltage
231VAC
and hold the "OFF" (circle) button until you hear a faint click.?
Yes it become completely off with the OFF button pressing.
May you require more clarification so do let us know
Your earliest response will be highly appreciated
Zakir
Any Update
Zakir
Dear team,
Any update .
Zakir
Kindly let us know its lost tracking daignosting for repairing PCB.
Rgds
Zakir
Hi Zakir,
