SURT 8000 XLI batt replacement
Send InviteCancel
Posted: 2021-06-3009:40 PM. Last Modified: 2024-03-0611:52 PM
Hi All,
i'm using SURT 8000 XLI to power up critical load (DCS system) that cannot be shutdown, i plan to replace the battery since the replace battery indicator was on. would someone help me to explain step by step procedure to replace the battery without affecting to the load operational?
