SUA1500RM2U - AP9617 - APC 940-0020C serial cable not communicating, cant reset AP9617
  • SUA1500RM2U - AP9617 - APC 940-0020C serial cable not communicating, cant reset AP9617
Spazhead_apc
Spazhead_apc
Cadet
Posted: ‎2021-07-08 06:01 AM . Last Modified: ‎2024-02-15 12:10 AM
2297
Hi, I bought a used SUA1500RM2U that came with the AP9617 management card.  I read in the manual that i need a APC serial cable to connect to PC to reset the AP9617.  I bought a new cable off ebay APC 940-0020C.
I hooked up the serial and set my only serial port to 2400-8-N-1-N COM1 in windows
I used putty and set it to the same serial speed above.
pressed enter in putty, nothing on the screen.
tried different speeds 9600-8-N-1-N
reconnect with putty, no output on screen.
then i tried to do the reset procedure anyways.
pressed and released the reset button on AP9617 card,  LED flash quickly, I pressed and released the reset button again.
i then pressed my enter button continuously until the LED stop flashing and remained steady pressed some more.
Still no prompt on my PUTTY.
I then removed the AP9617 card out of the UPS think it may be defective.
try connecting serial with putty again, nothing on screen.
then i removed the battery from the AP9617 and left it alone for a week, hoping it would lose it settings, but still nothing.
any help is appreciated, or do i have a defective serial port an/or AP9617?
BTW, when I plug the UPS using the USB cable to my UNRAID server, it reads everything about the UPS no problem.
I just want to try to get the AP9617 card working
Posted: ‎2021-07-08 06:02 AM . Last Modified: ‎2024-02-15 12:10 AM
You need smart signalling cable 940-0024. Cable 940-0020 is simple signalling meaning it is one way communications. From UPS to computer. The smart signalling cable is two way.
Janeway
I believe on that UPS using USB disables the serial port. To re-enable the serial port, unplug the UPS and its battery, wait for a few seconds for the fan to stop spinning and the lights to go out, and then re-assemble the unit.
