SRT10KRMXLI - Connect Battery
Showing results forΒ
Did you mean:Β
  • SRT10KRMXLI - Connect Battery
Djripper666
Ensign Djripper666
Ensign
Posted: β€Ž2022-05-30 03:42 AM
17
4730
I have the error coming up as "Connect Battery Backup Not Available". I had the same model but the 8k was working fine batteries are new Connections seem fine all was working. I upgraded to the 10k took the batteries out of 8k and into new 10k and that error appears. What steps could I take? All batteries individually read 13v min.
Replies 17
JonPro
Commander JonPro Commander
Commander
Posted: β€Ž2022-06-16 11:12 PM
4593
@Djripper666
Will you be able to double-check and share a photo of the actual battery voltage?  Each battery string on the APCRBC140 should measure at least 85v DC in order to be recognized by the UPS.
Kindly share as well if you are seeing any event code on the LCD display, as well as the NMC debug file.  You can refer to the FAQ provided below to guide you on how to retrieve the debug file.
See FA156131 - How can I download Event, Data, Configuration, and Debug files from my Network Management...
See Operation Smart-UPS On-Line 8/10 kVA, 208/220/230/240 Vac TWR/RM 6U
Djripper666
Ensign Djripper666
Ensign
Posted: β€Ž2022-06-22 03:07 AM
In response to JonPro
4540
Hello, all read 91v or above. I am trying to get the logs but I can't seem to access the Web gui. Using putty I can connect and use the command "web" and see https is enabled with port 443 how ever when I try and access it please see photos.
Djripper666
Ensign Djripper666
Ensign
Posted: β€Ž2022-06-22 03:10 AM
In response to Djripper666
4539
TonKei
Lieutenant TonKei Lieutenant
Lieutenant
Posted: β€Ž2022-06-22 03:18 AM . Last Modified: β€Ž2022-06-22 03:20 AM
4536
Hello DJ
This might be a case of an expired SSL certificate.
We have a FAQ document on the issue that also details the mitigating actions
-> https://www.apc.com/ie/en/faqs/FAQ000233142/
Alternatively, you can open the HTTP communication via SSH and the web command. If the web UI is reachable then, it is a strong indicator that it is the above issue.
Best regards
Tonny Keinicke
Djripper666
Ensign Djripper666
Ensign
Posted: β€Ž2022-06-22 05:27 AM
In response to TonKei
4522
would you please be able to provide steps on how to do that through the ssh putty cli please? would you need to download the certificate separately to install it and if so where do i get it from? sorry not great with cli.
TonKei
Lieutenant
Posted: β€Ž2022-06-22 05:37 AM
Hello DJ
If CLI is not your thing I would suggest enabling HTTP with the "web" command (same as as when you checked that HTTPS was enabled) but this time around run the command "web -h enable" this should enable HTTP. last thing will then be to reboot the card with the reboot command.
After the reboot, check if you can reach the web UI by opening a browser and navigate to the IP of the card, but with http:// in front of the address.
That should enforce HTTP.
Best regards
Tonny
Djripper666
Ensign Djripper666
Ensign
Posted: β€Ž2022-06-22 06:14 AM
4514
ok so i have got all of the web stuff sorted now i have attached all the logs for my ups, they are .tar so how ever you wish to extract. the first two RBC1 bays caddies are at 101v and the RBC2 i have disconnected but still does not show up on the ups. Thank you for all your help peeps and looking forward to sorting this issue out.
Djripper666
Ensign Djripper666
Ensign
Posted: β€Ž2022-06-22 06:24 AM
ok now i cant seem to add the files to this forum so please click the link and download them.
https://drive.google.com/drive/folders/1_L9qzqSwnYzQmVa-WLgxbIq9VYuWYGxh?usp=sharing
TonKei
Lieutenant
Posted: β€Ž2022-06-22 06:31 AM
4509
Hey @JonPro
We managed to get the support file from the NMC for your review πŸ™‚
Best regards
Tonny
Djripper666
Ensign Djripper666
Ensign
Posted: β€Ž2022-06-22 07:13 PM
4496
Thank you hopefully we can find out what the problem is.
vannan5
vannan5
Cadet
Posted: β€Ž2023-05-17 05:02 AM
Hello DJ,
did you managed solve this issue.We have recently purchased same model UPS out of the box we are getting this issue.
vannan5
vannan5
Cadet
Posted: β€Ž2023-05-17 05:04 AM
hello tonkei,
we are also facing the same issue on this model. we are wondering buy any chance. you have managed to get a solution.
vannan5
vannan5
Cadet
Posted: β€Ž2023-05-17 05:06 AM
3798
Dear Jon,
hello i am facing exact same issue on this very same model. any help would be much appreciated.
Djripper666
Ensign Djripper666
Ensign
Posted: β€Ž2023-05-17 03:40 PM
In response to vannan5
No sorry I haven't heard anything from them at all hopefully this comment will re bring it to thier attention.
Djripper666
Ensign Djripper666
Ensign
Posted: β€Ž2023-06-03 03:42 PM
Can I ask what's happening with the log files have you gone over them? I'm sure because they have not been fix and not charging because it was so long ago I dare say I will have to buy more batteries again now even though they were brand new
Djripper666
Ensign Djripper666
Ensign
Posted: β€Ž2025-08-06 02:10 PM
1021
Years later and still nothing
Kirk
Posted: β€Ž2025-08-07 07:20 AM
Have you submitted a service request for this problem and referenced this thread with APC Technical Support?!?
If not do so now . . . If you have submitted a formal service request include the incident number with the new one.
Using the APC Forum will not get any traction or resolution to your problem. Regardless, provide the following logs from the system: Event, Data, UPS
Provide a screen capture from the NMC’s webpage under the About Tab: NMC / UPS.
Questions Ask . . . πŸ‘
Β
