Posted: 2021-06-30 12:31 AM . Last Modified: 2024-03-11 04:03 AM
I installed the PowerChute Network Shutdown v4.2 VMware Virtual Appliance. When the .ovf is deployed and the VM is powered on, you walk through a text based initial setup. In that setup, there's an option to change the root password which is what I did. After setting up all other parameters I closed the initial setup and now I'm presented with a login screen but I can't login because it won't accept the password.
At first I thought I f'd up in the initial setup by entering a different password from what I wrote down so I deleted the VM and started over again but at the second installation of the VM, I have the same problem. I can't login with username: root and password: changed at initial setup
What's the issue here?
edit: to avoid confusion, I'm talking about the Linux terminal account here, not the Powerchute account (Powerchute works fine).
Posted: 2021-06-30 12:32 AM . Last Modified: 2024-03-11 04:03 AM
Had the same problem. The password i entered on initial setup was not saved.
Do not use the key "q" to exit any masks! This ends the setup or mask without saving the changes.
Use "c", continue.
Sorry for the inconvenience. The root password is what is entered during the initial configuration. There is no back door password however you may find information on the web for resetting CentOS 7 root password.
I suggest reinstalling and configuring the root password to something simple as a test. Try PCNSlogin. You can change the password after once logged in with the command passwd. I would also create a secondary user and password during the initial setup.
Hi
I've the exact same problem. Did you find a solution that worked for you?
Regards
Janis Wolf
Nopes, haven't got time to look into it and I'm a bit wary to force a password reset. I honestly think Schneider is overlooking something here since I had this problem with 2 different installs (see startpost).
Did you manage to find a solution since you've posted?
Greets
Hi
Thanks for your answer!
Unfortunately not... I didn't tried a force password reset. But I'm going to try a system upgrade since APC provides a way of updating 4.1 to 4.2. And 4.1 is working fine after the installation.
Found this article: http://www.apc.com/us/en/faqs/FA276378/
Friendly regards
Hi
Well the software upgrade from 4.1 to 4.2 did not work, so I tried resetting the root password. I had to boot in single user mode, mound the file system and then reset the password with passwd . I used the following guide to boot in single user mode:
https://vpsie.com/knowledge-base/boot-single-user-mode-centos-rhel-vpsie/
That worked for me.
Hope this helps.
Use "c", continue.
