Posted: 2021-06-30 06:15 AM . Last Modified: 2024-03-08 01:20 AM
I just want to make sure I have theses settings right. On the NMC I have the following settings:
Start of Shutdown
Low Battery Duration: 07 minutes
Shutdown Delay: 020 seconds
Maximum Required Delay: 7 minutes
Basic Signaling Shutdown: Enable
Duration of Shutdown
Sleep Time: hours [0 to 359.9]
End of Shutdown
Minimum Battery Capacity: 00%
Return Delay: 000 seconds
I just wanted to make sure that the above means that when there is 7 minutes of runtime left on the battery that it will shutdown the PowerChute clients. Thanks for any help!!!
Message was edited by: tbeck1983
Ok I have deployed the clients. Thanks for you help!!
Right, you want to set the low battery duration to 7 minutes then, and of course, you need to install the powerchute network shutdown software on all the systems you want to shut down.
