Questions about configuring the AP9631
Send InviteCancel
Posted: 2021-07-0103:10 AM. Last Modified: 2024-03-0511:09 PM
I have questions about configuring the Network Management Card AP9631.
1)How does the UPS will perform shutdown If I do not choose any CheckBox in the "UPS -> Configuration -> Shutdown -> Section Controlled Early Shutdown"?
UPS will shutdown when the UPS runtime remaining will be equal Low Battery Duration + Shutdown Delay + built-in UPS 2-minute delay? When time starts counting event Low Battery Duration?
2) If I specify "UPS runtime remaining is less than" equal to 9 minutes UPS start shutdown procedure when the remaining battery life will make 9 minutes, regardless of "Start of Shutdown" section settings? The same is true to other settings "Controlled Early Shutdown" section?
3) If I choose three checkbox in section "Controlled Early Shutdown" which priority will be at each of them?
