Question: ACPA4000 compressor cycling and noise dampening
  • Question: ACPA4000 compressor cycling and noise dampening
Posted: ‎2021-06-28 03:12 AM . Last Modified: ‎2024-02-14 10:30 PM
871
Hi.
I have a question regarding our NetworkAIR ACPA4000.We just installed this in our small server room. We just relied on fans before - i know not a good idea, so I have very little experience with cooling. The unit cools the room quite quickly so I think it has more than enough capacity. My question is the compressor seems to run for about 10 minutes then the compressor stops and the fan continues, but only for 1 minute then the compressor runs again for approx 10 minutes, then off for 1 min, and it continually cycles like this. Is this normal behavior for these units? As I mentioned I have nothing to compare this to. We have the set point at 63 degrees with the max dead band of 3 degrees. We tried various combinations of set point, dead band and low and high fan , which have not had any effect. The only reason this is an issue is the unit is quite loud ( we have both the supply and exhaust piped to our office plenum), and when the unit transitions from compressor on and off the noise is more annoying - if it ran continually i think the noise would become more of a constant background noise that a person could become accustomed too. So to summarize, is the compressor on for 10 min off for 1 min cycle normal or is there some configuration issue? Second is there some way to dampen the air flow noise without restricting the airflow?
Any advice would be appreciated.
thanks
Posted: ‎2021-06-28 03:13 AM . Last Modified: ‎2024-02-14 10:30 PM
Hi
Thanks for the advice, i called and the tech explained that it is most likely that the cooler is not getting enough of a heat load on the intake, so the compressor shuts down. The room layout restricts us to much of what we can do, so I am going to have to be creative in directing the heat from the rack to the cooler. I pretty much have the placement of the cooler backwards to what I probably need. I was more concerned with the placement of the hoses for the condenser I did not give much thought to the air flow to and from the unit itself.
thanks again
Dave
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
Sisko
Sorry for the delay. I've sent an email to our cooling tech support team and hope to have something for you later today.
Update:
They asked that you call into them and speak to them regarding this:
888-695-6500
Message was edited by: The Notorious K.M.P.
Hi
thanks again
Dave
