Problem AP9619 and Smart-UPS RT 10000 XL
  • Problem AP9619 and Smart-UPS RT 10000 XL
Posted: ‎2021-06-30 02:33 AM . Last Modified: ‎2024-03-10 11:18 PM
942
I have a problem, ping loss AP9619 and Smart-UPS RT 10000 XL
American Power Conversion Network Management Card AOS v3.7.3
(c) Copyright 2009 All Rights Reserved Smart-UPS & Matrix-UPS APP v3.7.2
Name : Unknown Date : 05/20/2011
Contact : Unknown Time : 15:51:55
Up Time : 0 Days 0 Hours 3 Minutes Stat : P+ N+ A+
Environment : Thresholds Disabled, Contact Alarms Disabled, Relay OK
Smart-UPS RT 10000 XL named APC_UPS : On Line, No Alarms Present
[root@inet ~]# ping -c 20 -i 0.7 192.168.63.10
PING 192.168.63.10 (192.168.63.10) 56(84) bytes of data.
64 bytes from 192.168.63.10: icmp_seq=2 ttl=254 time=3.72 ms
64 bytes from 192.168.63.10: icmp_seq=16 ttl=254 time=3.59 ms
64 bytes from 192.168.63.10: icmp_seq=18 ttl=254 time=3.15 ms
64 bytes from 192.168.63.10: icmp_seq=20 ttl=254 time=2.75 ms
--- 192.168.63.10 ping statistics ---
20 packets transmitted, 4 received, 80% packet loss, time 13330ms
rtt min/avg/max/mdev = 2.753/3.307/3.723/0.386 ms
[root@inet ~]#
earlier periods simply disappeared network and helped to distortion of the cord
I used a straight cable, the problem is the same, this is not the fault of my networking equipment, and some problem with the AP9619, on that appealed to you for guidance.
have you tried a direct connection between the computer and AP9619 to rule out a network issue? you can try a constant ping and if you still have packet loss, try a new network cable. if it still shows packet loss, then i would suspect either the AP9619 or network adapter on the other end which you could rule out im sure if you are using a separate computer to connect directly to the AP9619 than you are to show us the ping statistics here.
ok, well i am not sure what else we can do if you have already done all of that. if you can prove that you have tried those steps, i suggest you contact APC tech support for your region and if the AP9619 is under warranty, inquire for a warranty replacement.
