  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
PowerChute does not allow enough time to shutdown all VMs
  • Communities
  • Re: PowerChute does not allow enough time to shutdown all VMs
  • Subscribe to RSS Feed
5027
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
powerchute_guy_apc
Crewman powerchute_guy_apc
Posted: ‎2021-07-01 01:08 AM
332
This was originally posted on APC forums on 2/15/2012
I am able to shutdown one ESX cluster(test with only 3 VMs) using PowerChute 3.0 with no problems.
My issue is when I try to shut down a second cluster it does now allow enough time to shut down all the VMs on it. It seems the ESXi host has a two minute uptime after it receives the shutdown command. The cluster has 20 VMs, but it only gets to shutdown 3 VMs before the ESXi host finally shuts down.
I have played with changinig the order of the ESXi hosts on the vMA box, but I can only consitently shutdown my first cluster.
The cluster has two ESXi host running version 5.0.
Any help is appreciated.
david.grehan_at_apcc.com_apc
Crewman david.grehan_at_apcc.com_apc
This was originally posted on APC forums on 6/14/2012
See the following Kbase:
http://nam-en.apc.com/app/answers/detail/a_id/11622/kw/HA
Replies 8
Janeway
This was originally posted on APC forums on 2/16/2012
Try adding time to the "Command File Execution Duration". That should give your VMs a longer time before the UPS shuts down.
powerchute_guy_apc
Thanks for your reply.
Do I have to define a command file to run? Event though I do not need one? It does not let me save any changes to 'The command file needs this much time to complete (seconds): ".
powerchute_guy_apc
I added 600 seconds to the "The command file needs this much time to complete (seconds)" along with an empty command file. All it did was delay the shutdown of the ESXi host for another 10 minutes, but the host still turned off before shutting down all the VMs.
What am I missing?
This is PowerChute Network Shutdown version 3.0.
This reply was originally posted by Bernard on APC forums on 2/16/2012
Good day Powerchute Guy,
I hope this helps. [Configure PowerChute Network Shutdown to shutdown virtual machines on VMware ESX and ESXi|http://nam-en.apc.com/app/answers/detail/a_id/10380]
powerchute_guy_apc
Thanks for the reply Kulot, but I have read and configured those settings.
To summarize:
-The ESXi host does receive the shutdown command.
-The VMs start to shutdown, but it only gets to successfully shutdown 3VMs (total of 20) before the ESXi host turns OFF.
-It seems that the ESXi host only has about 2 minutes of up time after it receives the shutdown command..
-The VMs do not have enough time to shutdown before the ESXi host turns OFF.
Is there must be a setting I am missing.
Message was edited by: powerchute_guy
powerchute_guy_apc
Do the VMware Tools need to be current?
powerchute_guy_apc
Oooooooooooooops!
All I had to do was increase the "Shutdown Delay" time from 20 seconds to 480 seconds! I should take breaks more often.
Thanks to everyone that responded.
Now on the my second problem. How to shutdown the cluster without having High Availability vMotioning all VMs from one host to the other while PowerChute trys to shut them both down. =(
Additional options
