Posted: 2021-06-30 06:49 AM . Last Modified: 2024-03-07 11:53 PM
Hi , I am using AP7921 and experencing the problem like the subject. Can you please tell me what meaning it is? Is this unit faulty?
Thanks for the reply.
Sorry I wrote the wrong part number .
Please see the following info of this unit.
Model Number: AP7951
Serial Number: ZA0703012622
Hardware Revision: B2
Manufacture Date: 01/20/2007
MAC Address: 00 C0 B7 2D CE 6C
Management Uptime: 14 Days 2 Hours 9 Minutes
This issue occured with firmware 2.7.4. After upgrading firmware to v3.3.1, it was gone for 2 days. Now this issue happened again.
Hi Ann,
Please upgrade to the latest fw, v3.5.5.
http://www.apc.com/tools/download/software_comp.cfm?sw_sku=SFRPDU355&id=55&family=70&part_num=AP7951...
Keep an eye on it, let us know if it comes back again. If it does, we'll need to gather the events, data, and config logs.
Posted: 2025-11-04 04:14 AM
On the internet are various sources how to repair this.
I had the same problems with some Zero-U Rack PDU's (7951, 7952, 7953).
Since the warranty ended on these units, there is only one thing you can do...
After looking at the problem I found the following:
In most of the units, there is a CPU part (near the ethernet/serial port) which holds a Lithium BR2032 battery. This was still fine after >10 years for me.
The CPU, It's universal. It sends it's data on a BUS network which has the relays for the sockets.
Mostly the CPU and the BUS are fine. The thing that breaks is the internal Power Supply (PSU).
It has a PSU based of 2 parts, which are exactly the same. I saw that the 47μF 400V capacitors were bulky, so I measured the capacity... dead.. I first replaced one (but then the fuse in my house blew and the other one was bulky too). SO finally I replaced the two capacitors by part: Panasonic EEUEE2G470, Ø16x25mm.
Then it worked great and can continue for another 15+ years!
TLDR: Replace the 47μF 400V capacitors by Panasonic part: EEUEE2G470, Ø16x25mm (need soldering). It's a typical repair after 10-15 years in which the capacitors get old.. dry.. get warm.. bulky.. dead...
