PCNS v3.01 With ESXi 5
  • PCNS v3.01 With ESXi 5
emy26_apc
Ensign emy26_apc
Ensign
Posted: ‎2021-07-01 01:34 AM . Last Modified: ‎2024-03-06 01:34 AM
1611
Hi
i've followed documentation sited on VMWARE KB to install agent on my ESXi Host:
http://www2.schneider-electric.com/resources/sites/SCHNEIDER_ELECTRIC/content/live/FAQS/159000/FA159...
after the installation i got error (see attached)
same error appear on the documentation but i can't see the url for configuration..
Can you please help me?
emy26_apc
Ensign emy26_apc
Ensign
yes server is on the list with FQDN name. No i've used IP of the Remote host am i wrong?
Replies 5
you should use the IP of the vMA cause that is where PCNS is installed.
hello,
can you clarify what you mean? you can't see log in to the PCNS configuration? cause you should be trying to access the vMA's IP address and not the ESXi host because that is where PCNS is installed.
if you look at the attached document you pasted, pages 54/55 tell you what to do when the error you get comes up. you need to do the command listed:
sudo vifp addserver 10.218.45.20
in my example, 10.218.45.20 is the ESXi host and you'd replace that with your IP if it did not add during the installation. did you run that command? if so, then you need to do like i mentioned and go to the URL: https://:6547
i hope that helps.
emy26_apc
Ensign emy26_apc
Ensign
Hello what i've tried to do is to lauch command sudo ./install_en.sh
and it says Failed to add ESXi host
To add the host manually please run - sudo vifp addserver (my ip address)
at the end of command i've tried that but it still says: your Host (my IP address) is already a vMA target.
after that i've tried to open https://myipaddress:6547/
but i don't take PCNS webpage for configuration
did you run the listservers command listed to verify you see it in the list?
and you are using the IP address of the vMA it sounds like on port 6547..?
emy26_apc
Ensign emy26_apc
Ensign
