PCNS cannot communicate with NMC when directly connected to host
Send InviteCancel
Posted: 2021-07-0806:07 AM. Last Modified: 2024-02-1512:06 AM
I have an AP9631 NMC that I want to use to shutdown an ESXi 6.7 host running on a Dell R440, using the virtual appliance containing PCNS 4.2.
If I connect NMC Ethernet port to one of R400 NICs, Powerchute cannot communicate with NMC. My other virtual machines also cannot ping NMC. If I connect NMC to my laptop, I can access it normally.
However, if I connect NMC to a physical switch and then connect this switch to one of R440 NICs, everything works fine: PCNS finds the NMC and the shutdown feature works as expected.
Why PCNS cannot communicate with NMC when it's directly connected to the host?
I don't think it's an authentication issue, since it works fine when connected to the physical switch.
Some information:
ESXi IP address: 10.0.240.201, manually set.
NMC IP address: 10.0.240.205, manually set.
R440 has 4 NICs, all of them on the same vSwitch, which is also connected to the VM Management network.
The physical switch that do the trick is a Rockwell Stratix 5700, running Cisco IOS.
UPS is a SRC2000XLI.
ESXi host is licensed (Essentials kit).
I have two virtual machines running Windows Server 2012R2 besides PCNS VM, if it matters.
