PCNS 4.3 Plug-in for vSphere 6.7
  • PCNS 4.3 Plug-in for vSphere 6.7
Posted: ‎2021-06-30 05:18 AM . Last Modified: ‎2024-03-08 02:42 AM
1154
Have performed a clean install of PCNS 4.3 appliance but client plugin does not appear in vSphere 6.7.
It is listed as Incompatible under Administration - Client Plugins - with "The plug-in supports  https://jpgtopdf.onl/ only vSphere Web Client (Flash)"
I have the Powerchute vSphere Plug-in option selected under vCenter Server details. https://1921681001.id/
Any suggestions please? https://19216811.cam/
Thanks a lot! Good to know.
Replies 4
The Plug-in is only compatible with the Flash base vSphere web client. It is not compatible with the HTML 5 UI.
Note: the vSphere Plugin is not required for PowerChute to operate in terms of core functionality and providing graceful shutdown. The plug-in is simply a means of accessing the PowerChute UI from within the vSphere Client. If running Flex is not an option PowerChute can be access by opening a browser tab and entering the ip address of the PowerChute client. Example https://192.168.10.10:6547. Once that has been done you can bookmark the page for easy access.
Hi Bill,
Are there plans to create an HTML plugin for the vSphere Client 6.7 / 7.0 or later?
Cheers,
Vladi
There may be a plug-in developed in the future, but as of now there is nothing scheduled.
