OID for individual outlet metering on APC 8641 Rack PDU
  • OID for individual outlet metering on APC 8641 Rack PDU
Posted: ‎2021-07-09 04:26 AM . Last Modified: ‎2024-02-14 10:22 PM
1524
Hi, I need to measure power consumed by the individual server and I am using APC 8641PDU.
How can I get power usage of each individual outlet?  1 through 24.
OID “rPDUOutletStatusLoad” is supposed to get the results but its not bringing.
http://oidref.com/1.3.6.1.4.1.318.1.1.12.3.5.1.1.7
Thanks in advance.
Posted: ‎2021-07-09 04:26 AM . Last Modified: ‎2024-02-14 10:21 PM
Thank you Angela.
Here is what I get. I have machines connected to PDU
[root@ooios08 snmp]#
[root@ooios08 snmp]# snmpwalk -Os -Of -c ABC -v 1 X.X.X.X 1.3.6.1.4.1.318.1.1.26.9.4.3.1.7
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.1 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.2 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.3 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.4 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.5 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.6 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.7 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.8 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.9 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.10 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.11 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.12 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.13 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.14 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.15 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.16 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.17 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.18 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.19 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.20 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.21 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.22 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.23 = INTEGER: 0
.iso.org.dod.internet.private.enterprises.318.1.1.26.9.4.3.1.7.24 = INTEGER: 0
The OID you mentioned is intended for older Rack PDUs as noted here: http://www.apc.com/us/en/faqs/FA156179
For what you want, check under here - iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).apc(318).products(1).hardware(1).rPDU2(26).rPDU2Outlet(9).rPDU2OutletMetered(4).rPDU2OutletMeteredStatusTable(3).rPDU2OutletMeteredStatusEntry(1)
Theres a few OIDs in this table for current, power, peak power, etc. Power is rPDU2OutletMeteredStatusEntry(1).rPDU2OutletMeteredStatusPower(7) or 1.3.6.1.4.1.318.1.1.26.9.4.3.1.7 which you should get an instance returned for each outlet on AP8641.
Hope that helps you.
Thank you Angela.
