Posted: 2021-07-01 01:10 AM . Last Modified: 2024-03-06 02:00 AM
Using PowerCute Bus Ed 25 node sw, with web interface to configure settings. The UPS Configuration > General Settings has a parameter "Number of Connected Battery Packs" that is currently set to 1. I have just added an external battery so I assume 1 is the correct setting and it does not count the internal battery, correct?
Posted: 2021-07-01 01:10 AM . Last Modified: 2024-03-06 01:59 AM
oh ok. that unit has intelligent battery packs so you shouldn't need to edit the number at all 🙂
what UPS model is it? some UPS models count their internal battery packs as 1 and some do not. in some UPSs the battery packs are intelligent and others aren't. basically, it depends on the model and then we can give you an answer.
Sorry, it is the SMX2200RMLV2U - APC Smart-UPS X 2200VA
