No PCNS,low battery time, according event.
  • No PCNS,low battery time, according event.
Posted: ‎2021-06-28 02:52 AM . Last Modified: ‎2024-02-14 10:40 PM
1121
sorry in upfront. I know that the web is full of discussions and question about what is low battery condition and so on.
First of all, I don't want to use PCNS or whatever SW on the clients. We have LX clients and have configured SNMP Traps on them.
Basically all we want to do is to receive a notification for the "last 10 Battery Minutes" and from there decide our self in which order or how
the shutdown happens.
I did some basic test. I attached some load (not shutdown able... beamer)  to the battery and removed the input power.
I watched all the emails flow in. The amount of repetition is because of the "repeat" setting in the Events setting.
So here they are:
50xUPS: On battery power in response to rapid change of input.
8x: Critical - UPS: The battery power is too low to continue to support the load; the UPS will shut down if input power does not return to normal soon.
1x: Warning - UPS: Main outlet group, UPS Outlets, has been commanded to shutdown with on delay.
1x Warning - UPS: Switched outlet group 1, Outlet Group 1, has been commanded to shutdown, sequenced.
1x Informational - UPS: No longer on battery power.
1x Informational - UPS: The graceful shutdown period has ended.
4x Informational - UPS: A low battery condition no longer exists
5x Warning - UPS: The power for the main outlet group, UPS Outlets, is now turned off.
5x Critical - UPS: The output power is turned off.
5x Critical - UPS: The battery power is too low to support the load; if power fails, the UPS will be shut down immediately.
5x Warning - UPS: The power for switched outlet group 1, Outlet Group 1, is now turned off.
For all what I have read now in the forums / web I would assume that
"Critical - UPS: The battery power is too low to continue to support the load; the UPS will shut down if input power does not return to normal soon."
is the indication for my desired "last 10 minutes" Battery Power.
Now the mystery begins. I did this test two times. One time with the default setting of 2 minutes "Low Battery duration", and one time with 10 minutes "Low Battery duration"
For both tests I can see that
comes appr. 10 minutes before
"Warning - UPS: Main outlet group, UPS Outlets, has been commanded to shutdown with on delay."
11/12/2015 15:39:44 Device UPS: The power for switched outlet group 1, Outlet Group 1, is now turned off.
11/12/2015 15:39:44 Device UPS: A low battery condition no longer exists.
11/12/2015 15:39:44 Device UPS: The battery power is too low to support the load; if power fails, the UPS will be shut down immediately.
11/12/2015 15:39:43 Device UPS: The output power is turned off.
11/12/2015 15:39:43 Device UPS: The graceful shutdown period has ended.
11/12/2015 15:39:43 Device UPS: No longer on battery power.
11/12/2015 15:39:43 Device UPS: Switched outlet group 1, Outlet Group 1, has been commanded to shutdown, sequenced.
11/12/2015 15:39:43 Device UPS: Main outlet group, UPS Outlets, has been commanded to shutdown with on delay.
11/12/2015 15:39:43 Device UPS: The power for the main outlet group, UPS Outlets, is now turned off.
11/12/2015 15:30:19 Device UPS: The battery power is too low to continue to support the load; the UPS will shut down if input power does not return to normal soon.
11/12/2015 15:30:05 Device UPS: A low battery condition no longer exists.
11/12/2015 15:29:23 Device UPS: The battery power is too low to continue to support the load; the UPS will shut down if input power does not return to normal soon.
11/12/2015 15:29:21 Device UPS: A low battery condition no longer exists.
11/12/2015 15:29:19 Device UPS: The battery power is too low to continue to support the load; the UPS will shut down if input power does not return to normal soon.
11/12/2015 15:29:18 Device UPS: A low battery condition no longer exists.
11/12/2015 15:29:13 Device UPS: The battery power is too low to continue to support the load; the UPS will shut down if input power does not return to normal soon.
11/12/2015 14:00:25 Device UPS: On battery power in response to rapid change of input.
Another:
10/19/2015 14:10:27 Device UPS: A discharged battery condition no longer exists.
10/19/2015 13:54:36 Device UPS: The power for switched outlet group 1, Outlet Group 1, is now turned on.
10/19/2015 13:54:34 Device UPS: The power for the main outlet group, UPS Outlets, is now turned on.
10/19/2015 13:54:33 Device UPS: The output power is now turned on.
10/19/2015 13:46:59 Device UPS: The power for switched outlet group 1, Outlet Group 1, is now turned off.
10/19/2015 13:46:58 Device UPS: A low battery condition no longer exists.
10/19/2015 13:46:58 Device UPS: The battery power is too low to support the load; if power fails, the UPS will be shut down immediately.
10/19/2015 13:46:57 Device UPS: The output power is turned off.
10/19/2015 13:46:57 Device UPS: The graceful shutdown period has ended.
10/19/2015 13:46:57 Device UPS: No longer on battery power.
10/19/2015 13:46:57 Device UPS: Switched outlet group 1, Outlet Group 1, has been commanded to shutdown, sequenced.
10/19/2015 13:46:57 Device UPS: Main outlet group, UPS Outlets, has been commanded to shutdown with on delay.
10/19/2015 13:46:57 Device UPS: The power for the main outlet group, UPS Outlets, is now turned off.
10/19/2015 13:38:00 Device UPS: The battery power is too low to continue to support the load; the UPS will shut down if input power does not return to normal soon.
10/19/2015 13:37:55 Device UPS: A low battery condition no longer exists.
10/19/2015 13:37:51 Device UPS: The battery power is too low to continue to support the load; the UPS will shut down if input power does not return to normal soon.
10/19/2015 13:37:49 Device UPS: A low battery condition no longer exists.
10/19/2015 13:37:46 Device UPS: The battery power is too low to continue to support the load; the UPS will shut down if input power does not return to normal soon.
10/19/2015 09:49:08 Device UPS: On battery power in response to distorted input.
1.) Please confirm if "Device UPS: The battery power is too low to continue to support the load;" is the indication for the "low battery duration"
2.) Why did I get two times 10 minutes ?
3.) What is the Event of the "real" shutdown of the UPS Outputs, without any delays etc.. e.g. " is now turned off. " ?
4.) What means "Device UPS: A low battery condition no longer exists. " I don't understand  why this shows up. Why is the low battery condition over ?
Thanks for your comments.
i added the data log here:
Smart-UPS 2200
Date Time Vmin Vmax Vout Iout %Wout %out FrqOut %Cap Vbat Tups
11/12/2015 15:42:14 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 46.44 27.00
11/12/2015 15:37:14 0.00 0.00 229.59 1.81 18.19 18.80 50.00 5.00 44.00 27.00
11/12/2015 15:32:14 0.00 0.00 231.00 2.00 18.80 20.80 50.00 11.00 45.06 26.50
11/12/2015 15:27:14 0.00 0.00 231.00 2.06 19.50 21.39 50.00 16.00 45.88 26.09
11/12/2015 15:22:14 0.00 0.00 231.00 2.16 19.50 22.09 50.00 20.00 46.44 25.59
11/12/2015 15:17:14 0.00 0.00 231.00 1.50 16.19 15.59 50.00 24.00 46.97 25.19
11/12/2015 15:12:14 0.00 0.00 229.59 2.22 20.09 22.69 50.00 28.00 47.25 25.19
11/12/2015 15:07:14 0.00 0.00 229.59 2.22 20.09 23.39 50.00 32.00 47.50 24.69
11/12/2015 15:02:14 0.00 0.00 229.59 2.22 20.09 23.39 50.00 36.00 47.78 24.30
11/12/2015 14:57:14 0.00 0.00 229.59 2.22 19.50 23.39 50.00 41.00 48.03 23.80
11/12/2015 14:52:14 0.00 0.00 231.00 2.22 20.09 23.39 50.00 46.00 48.31 23.39
11/12/2015 14:47:14 0.00 0.00 228.30 1.81 14.89 18.80 50.00 51.00 48.84 22.50
11/12/2015 14:42:14 0.00 0.00 231.00 1.81 14.89 18.80 50.00 56.00 48.84 22.00
11/12/2015 14:37:14 0.00 0.00 231.00 1.81 14.89 18.80 50.00 58.00 49.13 21.59
11/12/2015 14:32:14 0.00 0.00 228.30 1.81 14.30 18.80 50.00 63.00 49.41 21.09
11/12/2015 14:27:14 0.00 0.00 229.59 1.81 14.30 18.80 50.00 67.00 49.41 20.19
11/12/2015 14:22:14 0.00 0.00 229.59 1.81 14.89 18.80 50.00 72.00 49.66 19.80
11/12/2015 14:17:14 0.00 0.00 228.30 1.81 14.89 18.80 50.00 76.00 49.66 19.30
11/12/2015 14:12:14 0.00 0.00 228.30 1.81 14.30 18.80 50.00 81.00 49.94 18.89
11/12/2015 14:07:14 0.00 0.00 228.30 1.81 14.89 18.80 50.00 85.00 49.94 18.00
11/12/2015 14:02:14 0.00 236.09 229.59 1.81 14.89 18.80 50.00 86.00 49.66 18.00
11/12/2015 13:57:14 236.09 236.09 236.09 0.44 5.19 5.00 49.97 100.00 54.53 17.50
11/12/2015 13:52:14 234.69 236.09 236.09 1.91 21.39 20.09 49.97 100.00 54.53 17.50
11/12/2015 13:47:14 234.69 236.09 236.09 1.81 21.39 19.50 49.97 100.00 54.53 17.50
Smart-UPS 2200
