Posted: 2023-01-09 10:59 AM
Dear friends:
I've been tasked with logging into our rack UPS systems and figuring out when batteries need to be replaced, etc. I have one unit that doesn't allow HTTP or HTTPS access, and when logging into the UPS via SSL I find that I'm an administrator (with the credentials that I have). and that there is a checksum error on the web server. I'm assuming this can get fixed at some point with a firmware upgrade. I'm trying to get at the detbat and detstatus commands, however, these show "command not found".
detbat -all
E101: Command Not Found
apc>
Wondering if this is also a result of the checksum problem.....or what this issue is?
Thanks for any help in advance. --- L
Schneider Electric Network Management Card AOS v6.6.4
(c) Copyright 2018 All Rights Reserved
Name : apc030335 Date : 07/20/2022
Contact : Unknown Time : 22:14:13
User : Administrator
Up Time : 59 Days 23 Hours 1 Minute Stat : P+ N4+ N6+ A-
Type ? for command listing
Use tcpip command for IP address(-i), subnet(-s), and gateway(-g)
Posted: 2023-01-10 03:59 PM
Hi @lkeyes
Based on the information above, we can see that the Application (A-) was not loaded correctly and this is the reason why the detstatus and detbat commands wouldn't work.
Kindly reflash the firmware by downloading it from the link below. I have shared FAQ articles below for your perusal.
