Need (updated) info on AP9537
  • Need (updated) info on AP9537
Buran
Crewman Buran
Crewman
Posted: ‎2022-08-10 12:46 PM . Last Modified: ‎2022-08-15 02:53 PM
4886
Hi everyone,
First, a (hopefully) easy question:
My AP9537 network card has been previously working with Office365  SMTP.  I need to reconfigure it to use SendGrid, but I keep getting "Bad user name or password".   The auto-generated passwords for SendGrid are 70 characters long (can't make them shorter), and now I'm wondering what the max password length is for the network card software.
(Update 8/15/22) - According to APC, the maximum password length is 256 characters, so password length isn't an issue.
Second, can anyone point me to the correct firmware updates for this thing?  After searching the site for a couple hours, I hit this:
UPS Network Management Card v7.0.4 Firmware for Smart-UPS & Galaxy 3500 with AP9630/31/35 - SFSUMX70...
But when I try to run it, I'm told the firmware isn't compatible.
Thanks!
Matt-B
Lieutenant JG Matt-B Lieutenant JG
Lieutenant JG
Posted: ‎2022-09-01 09:15 AM
In response to Buran
Hi @Buran,
The "application module" is the firmware type that you would need to run in your system - in this case, SUMX, which is used for our second generation Network Management Card (NMC2) in a SmartUPS. The latest version of SUMX we have is v7.0.8, which can be downloaded here: https://www.apc.com/us/en/product/SFSUMX708/ups-network-management-card-v7-0-8-firmware-for-smartups...
If you're having issues upgrading the firmware, you can try to do it manually over FTP instead of using the bundled firmware upgrade wizard - we have instructions on how to do that here: https://www.apc.com/us/en/faqs/FA156047/#FTP
Replies 4
JonPro
Commander JonPro Commander
Commander
Posted: ‎2022-08-26 07:41 AM
4793
Hi @Buran
Thank you for reaching out to the SE Community, my name is Jon and I will assist you with this query.
To assist you with your query, it would be helpful if you can provide the actual hardware that you have where the AP9537 is installed to.  I am guessing that this is installed on an APC Rack PDU 2nd Generation.
If this is the case, the firmware that you have posted is meant to be used for network management cards (NMC) that are installed on a UPS.
You may download the latest rPDU firmware from this link, APC Rack Power Distribution Unit Firmware, Revision 7.0.8, For AP8xxx and AP7xxxB Series PDUs.
Should you need some help in upgrading the firmware, you may refer to this article, How do I upgrade the firmware on an APC Network Management Card (NMC) or NMC embedded device (Rack P...
I hope this helps.
Buran
Crewman Buran
Crewman
Posted: ‎2022-09-01 06:58 AM
In response to JonPro
4757
Hi @JonPro
I hope this is the info you need:
UPS
Model
Smart-UPS SRT 5000
SKU
SRT5KRMXLT
Network Card
Model Number
AP9537SUM
Serial Number
5A1838T00040
Hardware Revision
05
Manufacture Date
09/21/2018
Application Module
Name
sumx
Version
v6.5.6
Date
Apr 6 2018
Time
16:00:53
APC OS (AOS)
Name
aos
Version
v6.5.6
Date
Mar 30 2018
Time
16:51:08
APC Boot Monitor
Name
bootmon
Version
v1.0.8
Date
Apr 8 2014
Time
10:59:40
Matt-B
Lieutenant JG
Hi @Buran,
Buran
Crewman Buran
Crewman
Posted: ‎2022-12-19 03:01 PM
Thanks Matt.   I held off on doing this for a while, but everything updated with no problems.  Thanks for pointing me in the right direction.
