Posted: 2021-06-29 10:46 PM . Last Modified: 2024-03-12 01:09 AM
Do anybody have Firmware (OS 3.7.3 and App Version 3.7.1) of the hardware model 0G-9354 Symmetra px ?
Hi - this is not the latest firmware. Can I confirm with you exactly why you need it before I share it? I can also provide the latest firmware instead if you weren't aware there was a newer version.
Our APC Has a communication Problem with the metering board Volts or Loads are displayed Zero, only Frequency is displayed 50Hz. we did upgrade the NMC Firmware to the latest and nothing changed, but since the app version APP 3.7.1 is hacked at the front of the NMC we want it to be the way it was. it will be your goodness to send the version to me. fazail.waasai@gmail.com
I should mention The battery modules are failed, can the above problem happen due to lack of DC power? if so can i energize the DC bus by 192v external DC power bank?
Best Regards!
I am not sure about your question on this scenario and why it occurred but it sounds like there are larger problems going on here. You may want to sort out the battery issue and then we can see if a firmware flash is needed.
What do you mean by "...but since the app version APP 3.7.1 is hacked at the front of the NMC we want it to be the way it was." I don't understand what "hacked at the front of the NMC" - do you mean written?
It seems from your other thread, you are already in contact with local support so I'd defer to them in order to get your system and running correctly.
