NETWORK MENEGMENT CARD CONFIG'
  • NETWORK MENEGMENT CARD CONFIG'
Posted: ‎2021-06-30 06:49 AM . Last Modified: ‎2024-03-07 11:52 PM
1898
Hi
I am new with the forum and new to the NMC - I nedd to set up new IP on the card and instasll after that PowerChure
on my network -
I would like to get same info and procedures ....
I need the defult IP of the new MNC and then to install and config' with the new IP...
I need help to install PowerChute and configur' it
Any help will appreciated
Posted: ‎2021-06-30 06:50 AM . Last Modified: ‎2024-03-07 11:50 PM
Hi
on my network -
Replies 14
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
Sisko
Posted: ‎2021-06-30 06:50 AM . Last Modified: ‎2024-03-07 11:52 PM
Hello Eitan,
Can we help you with something?
I don't know what hapen with my "thread"
Need help co configure new NMC CARD I don't have the default IP
Need help to install PowerChoute and monitor about 10 UPS
TheNotoriousKMP_apc
Sisko
Eitan,
Here is a link for configuring the Network Management Card (NMC).
http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_faqid=3061&p_created=1069703361&p...
As for the Powerchute Clients, you would need to install PowerChute Network Shutdown on each of the clients. The version will vary based on the OS on the machine. Each, during setup, will be required to verify communication with the NMC, so be sure to have the Username/Password and IP address available during install.
Thanks for the respond
I will tray to configure the NMC cards
For the install the PowerChute I don't have PowerChute client I have the PowerChte "Business Edition Basic"
Can I install it on aserver and then to monitor each Nmc Card by the IP I confg' '??
Hi
If I would like to access to the a new NMC I would like to do it by browsing or telnet -I need the default IP !
And regarding the PowerChte install I have only the PowerChute business edition basic and I will install that on a server and than monitor all the UPS( 10) after I config'
them with new IP - do I need still install the PowerChute client wherein each ups?
Hi
Hi
TheNotoriousKMP_apc
Sisko
Eitan,
I do not know what is happening to the rest of your response, but it keeps getting cut off and posted multiple times.
I can see that I don't know why
after I done with the message I press the "add tread" but it showiing only the first line?
My question is :
Message was edited by: eitan
Posted: ‎2021-06-30 06:50 AM . Last Modified: ‎2024-03-07 11:51 PM
I don't know why my massages not showing up
I ( we) the company would like to monitoring the UPS'(10 UPS) on different location we are connecting to the UPS router/ wireless radio and need just monitoring the ups with PowerChute - busuness edition" that will be install on one of our server-that mean we are not installing "client" because -no computers....
I need the default IP of a new NMC I would like to log in the card first time by browsing or by telnet and then to configure the new IP
It is difficult to understand your actual question, but if you are using a Network Management Card, there is no default IP. The card needs to be given an IP address, which is explained in the document linked above in this thread. Also, you would not use PowerChute Business Edition, but PowerChute Network Shutdown to gracefully shutdown the servers being powered by the UPS. Business Edition uses direct one to one communication via serial or usb cable, while Network Shutdown communicates via IP. Each Network Shutdown client will talk to the IP address you have assigned to the Network Management Card. Then you can individually configure each client to shutdown based on different events.
Hope this helps.
Thanks.
If you are not local to the cards and trying to configure their initial IP addresses there are two other methods outlined in this kbase that you could attempt:
Hi
on my network -
