Model Smart-UPS X 3000 Alert Beep every 3 seconds; does not stop
Send InviteCancel
Posted: ‎2025-01-1305:50 AM
What does the system indicate the internal battery temperature is?!? The possible reason are the battery compartment is above the high limit and thus the declared fault or the sensor is faulty which is very unlikely.
What is the ambient temperature in the room where the system resides?!? Remove the battery cartridge and place a fan in the battery compartment for an hour and report back what the system indicates as the battery internal temperature is.
