MGE Galaxy 5500 UPS 30kVA - OIDs - Basic Output and Output Current
Send InviteCancel
Posted: 2023-06-0805:38 AM
I am monitoring an MGE Galaxy 5500 UPS 30kVA , and the following MIBS, which are available on other APC UPS units, are not available on this device. Can you please suggest alternatives for the following OIDs
.1.3.6.1.4.1.318.1.1.1.4.1.1.0 oid upsBasicOutputStatus .1.3.6.1.4.1.318.1.1.1.4.2.4.0 oid upsAdvOutputCurrent
Also, is the a full MIB file for this device available?
The management card specifications for the MGE Galaxy 5500 UPS 30kVA unit are as follows:-
