Local Management-To-NMC Integrated EM Sensor Communication Lost: Universal I/O at Port 1-2
  • Local Management-To-NMC Integrated EM Sensor Communication Lost: Universal I/O at Port 1-2
UPSSupport
UPSSupport
Cadet
Posted: ‎2022-09-17 10:41 AM . Last Modified: ‎2022-09-17 10:47 AM
1543
Firmware upgrade to v7.x causes event log to fill up every second with the following errors.
 09/17/202213:29:51DeviceEnvironment: Lost the local network management interface-to-integrated Environmental Monitor (Universal I/O at Port 2) communication.
 09/17/202213:29:51DeviceEnvironment: Restored the local network management interface-to-integrated Environmental Monitor (Universal I/O at Port 2) communication.
 09/17/202213:29:50DeviceEnvironment: Lost the local network management interface-to-integrated Environmental Monitor (Universal I/O at Port 1) communication.
 09/17/202213:29:50DeviceEnvironment: Restored the local network management interface-to-integrated Environmental Monitor (Universal I/O at Port 1) communication.
This is affecting the cards performance, interface is slow to respond to all requests.
Model Number
AP9631
Serial Number
5A1522T13462
Hardware Revision
05
Manufacture Date
05/30/2015
Application Module
Name
sumx
Version
v7.0.8
Date
Jun 29 2022
APC OS (AOS)
Name
aos
Version
v7.0.8
Date
May 27 2022
APC Boot Monitor
Name
bootmon
Version
v1.0.9
Date
Mar 27 2019
Card is installed in an SMX1500RM2UNC
Have a pair of these UPS and AP9631 exact same hardware specs, both at the same firmware revisions, only the one card is having issues.
What I have done so far.
Various resets of the card - issue remains
BM>factory_reset - issue remains
reflash card with BM>xmodem
Rolled back to firmware version 6.5 - issue is gone
Rolled back to various 7.x versions - issue remains.
removed for an extended period of time and reseated the card
installed environment monitor cables, reset lost com alarm, reboot
Hopefully someone has some insight into this issue, as I can no longer use my environment monitors with the card in this state.
Thanks All for your input
JonPro
Commander JonPro Commander
Commander
Posted: ‎2022-09-25 04:09 PM
1474
Hi @UPSSupport
Thank you for reaching out to the SE Community, my name is Jon and I will assist you with this query.  Apologies for the inconvenience that the issue has caused.
I would normally disconnect everything that is connected to the network card and press the reset button quickly to reboot the NMC or reseat it.  Once it has booted up, I will then start connecting those peripherals back to the card and reboot it once more.
If possible, I also suggest reflashing the card once more.
UPSSupport
UPSSupport
Cadet
Posted: ‎2022-11-25 05:28 PM . Last Modified: ‎2022-11-25 05:29 PM
In response to JonPro
Have done the reflash and the reset and the reseat.
There are no sensors/peripherals connected to the card.
There never was, except for a test to reset the fault.
I want to connect sensors to it, but those i/o ports are in a fault state.
the errors every few seconds make the card almost unusable, as it consumes lots of resources recording faults continually.
Have picked up a replacement card, but would like to revive this one for another unit for environment monitoring.
thanks for the follow up.
