84422members
353607posts
Issues activating HTTPS on AP9619 with AOS 3.7.2
Lloyd.Robbins_apc
327
This was originally posted on APC forums on 6/17/2015
When I try and activate HTTPS for web access I get the "Accept Terms" screen, but it appears washed out and the check box is not visable. I am not able to successfully activate HTTPS access.
Tags (2)
Terry_Kennedy_apc
Re: Issues activating HTTPS on AP9619 with AOS 3.7.2
This was originally posted on APC forums on 6/18/2015
Note that the SSL implementation in 3.7.x doesn't interoperate with many current (up-to-date) browsers. I found a workaround for that, but perhaps APC will issue an official firmware update for it, since the AP9618 is still an actively sold product (AP9617/AP9619 are discontinued and replaced by the AP9630/AP9631, but all of AP9617/8/9 share the same firmware, so a fix for the AP9618 should work on the others).
2 Replies 2
This reply was originally posted by Jordan on APC forums on 6/17/2015
Hi Lloyd,
This is a known issue, trying configuring HTTPS via Telnet or directly editing the config.ini.
Terry_Kennedy_apc
