Is there a way to script powering off and back on of PDU ports?
  • Is there a way to script powering off and back on of PDU ports?
Jrussell_apc
Jrussell_apc
Cadet
Posted: ‎2021-07-09 04:24 AM . Last Modified: ‎2024-02-14 11:00 PM
3054
We have several APC PDU's racked (model AP8659EU3) and a non APC UPS powering our server room. What I was wondering was, do these PDU's have some sort of CLI to them or some sort of signal I can send to them to get them to power off (so the sockets and then back on again.
Basically I want to be able to switch off the power sockets in the event of a power cut, then when the power comes back on I want the system to power the sockets back on.
Ideally I would like to do this in Powershell, but if a batch file is the only way to get this to do what I want then I will make it work.
Any advice would be greatly appreciated.
B-DoubleE_apc
Commander B-DoubleE_apc
Commander
Hi James,
Our PDU's have a special scripting interface you can use  - info on how to access it, and what the command syntax is can be found here: http://www.apc.com/us/en/faqs/FA156163/
B-DoubleE_apc
Commander
Hi James,
jces
jces
Cadet
Posted: ‎2024-10-11 12:06 PM
This scripting interface (i.e.: appending "-c" to password) is no longer supported on device running with Network Management Card 3 (NMC3).
dpierce4776
Lt. Commander dpierce4776
Lt. Commander
Posted: ‎2024-10-14 09:48 PM
You can still do it with putty. And you might be able to do it with PLink. The only issue with doing it with putty is that putty must be the active window and you can not do anything else with the PC until it is done. Also if the PC goes to sleep it might interrupt the process script.
