Input power restored not running startup script
  • Input power restored not running startup script
Posted: ‎2021-06-30 07:41 AM . Last Modified: ‎2024-03-07 10:48 PM
777
Has anyone come across the issue where the event trigger "input power restored" does not run the script configured? My shutdown script runs perfectly with trigger "UPS on battery" and my startup script works perfectly when run manually but just doesn't seem to get the signal to run the startup on the PCNS trigger. I used to run the startup on event "powershute service started" and this worked but the new version of PCNS doesn't have this event anymore so I'm stuck. Any advice welcome. Thanks.
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
Sisko
Just to make sure I understand what's going on before I offer any advice, I need to make sure I read correctly. In a nutshell this is your problem:
PCNS 2.2.1 (Prior)
UPS: On Battery - Run Command File - worked fine
Input Power: Restored - Run Command File - worked fine
PCNS 2.2.3 (Now)
UPS: On Battery - Run Command File - works fine
Input Power: Restored - Run Command File - doesn't work
Are these the same command files? Is it possible you can run a command file just to simply call the command file you want to run? Sometimes the software/NMC gets picky about command files, and requires an initial command file to call it to run.
TheNotoriousKMP_apc
Sisko
PCNS 2.2.1 (Prior)
PCNS 2.2.3 (Now)
