Impossible UPS management
  • Impossible UPS management
adminDac
Crewman adminDac
Crewman
Posted: ‎2024-07-26 03:12 AM
1159
Hi.
We have a UPS SMT1500RMI2UC.
This UPS is equipped with a NIC. The administrator who preceded me had configured to be able to manage a server with Esxi. I need to review the management but I can't connect to the UPS NIC. I have the login credentials, but I can't use them, since no port is open for connection. I could restore the default configuration but then I would perhaps lose the work already done. Can someone give me advice on how to proceed? Thank you all
Kirk
Posted: ‎2024-07-27 06:15 AM . Last Modified: ‎2024-07-27 06:16 AM
1106
I’m not clear as to what you’re referring to when you say (NIC) so will provide some general information that may offer you more insight.
Your specific model APC UPS has a green Ethernet port. This specific port is used to connect to the APC Smart Connect Cloud Portal Service.
You would access the units settings, metrics, etc through that cloud based website once you logged in. ☝️ On the rear is also a rectangular plate which accepts the APC Smart Slot for their NMC (Network Management Card) which provides full local network access, control, and management of the UPS.
If you’re connected with the green Ethernet port and don’t have the NMC installed.
The only method to review the metrics, settings over the network is via the APC Smart Connect Cloud Portal Service. 🤦‍♂️
In this specific configuration there is (No) local (network access) to the unit. 👎
Lastly, the two other ports are intended to connect to a computer system running APC PCBE / PCSS software to facilitate the graceful shutdown of the system during a lights out event.
The two serial ports can also be used to connect to other third party software such as APCUPSD / NUT. Only one serial port whether it be the RJ50 / USB can be connected at any one time for use!
Let me know if that helps clarify the NIC question. 👍
Kirk
1107
adminDac
Crewman adminDac
Crewman
Posted: ‎2024-07-30 03:14 AM
In response to Teken
Hello Teken. First of all, thank you for the answer. By NIC, I meant a network adapter. With your answer I realized that the network card I have is the green one. Not others. I'll work with that. Thank you
