Human readable Notifications
  • Human readable Notifications
5060
138
Erasmus_apc
Sisko Erasmus_apc
112
Ervin
Ervin
Cadet
Posted: ‎2024-06-25 12:19 AM
605
Hello
Our company proudly uses APC products such as Galaxy VS 20kW, Smart-UPS RT 1000 XL, Smart-UPS SRT 2200 and others. We use notifications in the form of email  @aliases that go to our email and one for the SMS gateway that sends messages directly to our mobile phone from UPS.
Is it possible to change the form of the notification so that it is readable for the IT administrator?
For example
Server rom name:
IP adress:
The information code to transelate to our language.
For starters the server room name and IP will be helpful.
I understand some of the mesages that are below but location and som other info. will golden to see in the notification messages.
Informational - Energy Storage (0x5000A1): Charge voltage is set to float voltage level, 5/2/2024 11:39:56.
Informational - General (0x100050): The load is supplied from the inverters of the unit. The UPS takes the power from the utility, 5/2/2024 11:39:56.
Informational - Static Bypass Switch (0x900150): Communication link between SBSC and UC is OK, 5/2/2024 11:40:1.
Informational - Static Bypass Switch (0x900050): Static bypass switch is OK and working correctly, 5/2/2024 11:40:18.
Informational - NMC (0x3F): Unable to update NTP, 5/5/2024 15:12:33.
Informational - Energy Storage (0x5000A0): Charger is off, 5/6/2024 9:0:1.
Informational - Energy Storage (0x500291): Battery self-test is running, 5/6/2024 9:0:1.
Informational - Energy Storage (0x500296): A scheduled battery self-test has been started, 5/6/2024 9:0:0.
Warning - Energy Storage (0x500092): The load is drawing more power than the UPS can draw from the
input, causing the UPS to draw power from the batteries, 5/6/2024 9:0:1.
Informational - Energy Storage (0x500293): Battery self-test has been completed, 5/6/2024 9:4:15.
Informational - Energy Storage (0x500280): The battery capacity is above 75%, 5/6/2024 9:4:15.
Informational - Energy Storage (0x5000A1): Charge voltage is set to float voltage level, 5/6/2024 9:4:25.
Informational - Energy Storage (0x500090): The UPS is charging the batteries, 5/6/2024 9:4:25.
Informational - General (0x100050): The load is supplied from the inverters of the unit. The UPS takes the power from the utility, 5/6/2024 9:4:25.
Informational - Input (0x200160): Input ramp-in has been completed, 5/6/2024 9:4:25.
Warning - Energy Storage (0x500092): The load is drawing more power than the UPS can draw from the input, causing the UPS to draw power from the batteries, 5/7/2024 9:0:1.
Informational - Energy Storage (0x500091): The UPS batteries are resting, 5/7/2024 9:0:1.
Informational - Energy Storage (0x5000A0): Charger is off, 5/7/2024 9:0:1.
Informational - Energy Storage (0x500291): Battery self-test is running, 5/7/2024 9:0:1.
Thank you for info. Ervin
Kirk
Posted: ‎2024-06-25 12:13 PM
Almost everything related to the information such as: Name, Contact, Location, System Messages, is in the ID Tab.
Every email includes the date, time, serial number, NMC serial number, active fault, error code, IP Address, URL.
