How voltage regulator works
Send InviteCancel
Posted: 2021-06-2612:25 AM. Last Modified: 2024-03-1902:54 AM
Hi, everyone,
Voltage regulator is used to regulate voltage level. When a steady, reliable voltage is needed, then voltage regulator is the preferred device. It generates a fixed output voltage that remains constant for any changes in an input voltage or load conditions. It acts as a buffer for protecting components from damages.
